Is there anything wrong with the way you have them, or just want them to look clean? Just curious cuz thats how mine look but i got 4 runs temporally, wanted the system to play already.
i want them to look clean and its a pain in the ass to take em off and on when i am redoing stuff and i will do it till everything is right. what i want is a distribution block with 1 1/0 in and 3 1/0 out make a super short run from the batt to the block the batt terminals are all cut up and same with the ring terminals it looks like shit
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Only 3 and you want a buss bar? Seems like a waste of metal. Adding metal does add resistance. I have put over 10 runs on one terminal before, don't know how you are having issue with three....
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
it all looks like shit
i want to clean it up thats all
BIG 3
RF T400.4
all stinger wires
I have one of my d3100's with 4 1/0 ring terminals connected to the positive and negative. I could easily get up to 6 max per battery terminal. What i did was get the same brand ring terminal and cut/solder them onto the wires just like you normally would. Then when connecting them to the battery i made them in almost a star pattern. For example if you were looking at my terminal one would be in the 3 o'clock position and another in the 9 o'clock position, then another at the 12 o'clock and 6 o'clock.
The best terminals to do this with are the ones by rockford fosgate (at least from the few brands ive tried out). first of all they have huge ring holes for the bolt to pass through and have a huge opening for you to feed more wire into the ring to solder and hold in place. Also they have a bigger face area where it will come into contact with your positive or ground than other terminals ive used.
Below is a quick pic of the battery bank in the back of my envoy. You can see on the left side where my positive terminals are that theres one battery with 4 ring terminals on one battery post.
  • Who's Online   1 Member, 1 Anonymous (See full list)
