OK i'm going to be building a box for a friend of mine sometime and he has 4 15's that are mtx thunder 8000's and was wanting some thoughts of the box i design i did for it
here are the spec's for it
415.jpgdo you think i have enough port area
here is the box ( the bright colors are just to show the different boards and where the port is)
Edited by justin_garrett
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
Have you modeled it in anything like WinISD? 2.5 cubes per seems smallish-average but it's hard to tell without seeing a response curve.
2007 Pacifica
about 2.25 net cubes is what the mtx site says but i will take any suggestions any one has and i haven't ran it in winISD yet
2000 Eclipse
4 of those woofers only displaces .18 cubes? and what kinda bracing do you plan to use in the box?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I've been generally happy with adding 20% volume and more port, tuning a little deeper. Seems to do more than cramming more cone area in less box, especially with the lowz. YMMV but I'd model in WinISD and play around with volume.
The box I built for my RF 15 gets stupid low when compared to what the manu recommends built a 3.5cube over 2.6 they recommend... Marketing depts make them keep the #s low so they can sell more subs to more people... Just think, if you didn't think you had room in your car for a 12, but the manu says you do, you'll probably buy one, even though the sq will be marginal.
2007 Pacifica
i cant really get the hang of winISD so i was thinking of maybe 12 to 13 net cubes with around 15 to 16 in2 per 1 foot of port do you think that would be any better
2000 Eclipse
Yes I do! But I'd keep it similar in style to what you designed. It's a good one :drink40:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
WinISD is pretty easy. You do have to do a couple things first...
Find the T/S params of your subs (Qts, Qes, Vas - get the manual)
Click on New and make new entries for your subs. watch out for standard/metric units... that will throw it off. Just click on the unit (The cm, in, ft, etc.) to toggle through.
after that, click on new again, choose your sub and it's easy from there.
For comparison, it doesn't hurt to add subs to the list you've had before, then when you model a certain enclosure volume and port tuning, you have something to compare to.
WinISD does not take into account cabin gain, so the curves are close to what you'd see if you put your enclosure on your driveway and measured it. It's just a tool to help you get an idea of what a certain enclosure design will do before you go out and build it.
2007 Pacifica
i tried the winIsd i put the T/S specs in but i just couldn't understand what to really look for but i went ahead and changed some specs in torres box calc and this is what im looking at now
now have 11.78 cubes net and 16.98 in2 per foot of port
2000 Eclipse
