DudeWith4x4 Posted November 11, 2011 Report Share Posted November 11, 2011 Well I've stopped being lazy and decided to gravitex my T-line.. I'd like to seal it some before so I don't use as much on the edges.. Thanks for the info guys. -Ross Project Layla Truck: 99' F-150 Gathering things for my next build. SoloX18 build: http://www.stevemead..._1#entry1576460 RE T-line build: http://www.stevemead...-between-build/ Link to comment Share on other sites More sharing options...
ineeDBass419 Posted November 11, 2011 Report Share Posted November 11, 2011 Are you just looking for somthing to just soak into the mdf so you don't use as much?or are you looking to make it stronger also? If your just looking for somthin to soak into the wood,then jus buy some cheap spray paint and put a few coats on there.or you could just put a coat of resin on it xbox 360 gamertag-greenrocks420 Not insulting you or anything, but did you just call us "bloody winging fairies" ? Link to comment Share on other sites More sharing options...
DudeWith4x4 Posted November 11, 2011 Author Report Share Posted November 11, 2011 I was looking for something that I would use as much and make it cover better aswell. I don't think I need to strengthen it atm.. Its only got 100rms on it and all. I may do the resin but I was wanting a cheap solution. Thanks for the reply man. -Ross Project Layla Truck: 99' F-150 Gathering things for my next build. SoloX18 build: http://www.stevemead..._1#entry1576460 RE T-line build: http://www.stevemead...-between-build/ Link to comment Share on other sites More sharing options...
Sanitarium Posted November 11, 2011 Report Share Posted November 11, 2011 thing out some wood glue and paint it on. or coat it in spackleing Link to comment Share on other sites More sharing options...
DudeWith4x4 Posted November 11, 2011 Author Report Share Posted November 11, 2011 Hmmm. Never thought of wood glue. Thanks man. -Ross Project Layla Truck: 99' F-150 Gathering things for my next build. SoloX18 build: http://www.stevemead..._1#entry1576460 RE T-line build: http://www.stevemead...-between-build/ Link to comment Share on other sites More sharing options...
Blackedout Posted November 11, 2011 Report Share Posted November 11, 2011 Primer or resin. Trunk Build Log Link to comment Share on other sites More sharing options...
DudeWith4x4 Posted November 11, 2011 Author Report Share Posted November 11, 2011 Like primer sealer or surfacer? -Ross Project Layla Truck: 99' F-150 Gathering things for my next build. SoloX18 build: http://www.stevemead..._1#entry1576460 RE T-line build: http://www.stevemead...-between-build/ Link to comment Share on other sites More sharing options...
Blackedout Posted November 11, 2011 Report Share Posted November 11, 2011 Yup. The gravitex should seal the box itself. Primer Sealer might make application easier... Resin may require sanding, but aerosol primer is normally the way to go when it comes to MDF boxes. Trunk Build Log Link to comment Share on other sites More sharing options...
CarAudioFab Posted November 30, 2011 Report Share Posted November 30, 2011 Yup. The gravitex should seal the box itself. Primer Sealer might make application easier... Resin may require sanding, but aerosol primer is normally the way to go when it comes to MDF boxes. . -Mark Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel Check out my forum section here on SMD for my builds and tutorial videos! Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication Link to comment Share on other sites More sharing options...
