C.Sanchez.A Posted November 22, 2011 Author Report Posted November 22, 2011 Looks much better, but you need to make sure the ports are at least the port diameter(4") from the bottom of the box. 4" would be better than 2.75"(you have to calculate thickness of wood when thinking about distance). 18.5-15=3.5" and 3.5"-.75"=2.75" Actually the height is 19", 19-15 = 4-0.75 = 3.25. Well at least I have enough port this time. I will make the adjustments with the ports and then I should be good to build! Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
CleanSierra Posted November 22, 2011 Report Posted November 22, 2011 Happy building! Let us know when you get started and post some pictures I love me some pictures.... Quote Im not the one you want to try to troll. Just a fyi for you.
Joe X Posted November 23, 2011 Report Posted November 23, 2011 No bracing? You could at least thicken the subs mounting surface. Quote
C.Sanchez.A Posted November 23, 2011 Author Report Posted November 23, 2011 No bracing? You could at least thicken the subs mounting surface. [/quote You just looked at the pictures, didn't you. There is going to be 45s in the corners and rods supporting the baffle. Quote Click Links To View Build Logs 1994 - Mazda B3000 (Daily/Toy/Show) 2002 - Mazda Protege (Daily) 1995 - Hyundai Accent (R.I.P.) 1984 - Bronco II (Restoration Project) Youtube Channel
