Sorry, its probably been asked before. Im sure it has. But anyway Im going to do the Big 3 and like many cars My 01 Grand Cherokee has + from battery going to alt and also another + from battery going to the fuse box. Will it hurt anything to just take that out and run straight to the alt? Also no more room on my Battery Terminal to just ADD my big 3, I need to replace my factory wire completely.
You should always leave factory wires intact. The extra factory wire is just that much little extra current your vehicle will get. And you should also fuse the after market wires used for the big 3. Just to protect your battery and or alt. :)
I wanted to do that...but like I said I have no room on my battery terminal to keep the stock wire and have the 0 guage Im using for the big 3. If I upgrade everything to 0 guage but leave the + from the battery to the fuse box ( which I think is 8 guage stock) Will I be alright? or will that need to be 0 guage?
as said before don't touch the factory wire. what you can do about the terminal is get an aftermarket one. look around on ebay.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Yes, you can leave the factory + from the bat to the fusebox. Cause all the power your fuse box needs to run your factory electronics is already being covered by your stock wiring.
2009 spring fling-iasca-rookie 1-Champion. 139.4db.
"I don't do enough, I just fool around
Ya'll can go to hell, how does that sound"~ Tech N9NE
4 15" Memphis. and 1 Big ass box. <-Sold to fund more power.
Kicker l5s
To many wires in it already
the two 8 gauge wires on the far left spot are my stock wiring....so its a bad Idea to completely eliminate my stock wiring and just run 0 guage and leave the 8 guage + from battery to fuse box?
you need a battery with side posts bro. all + factory wires could be connected to the + side post and then that would free up your + top post for your audio. that's what i did to my truck.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
just put a distro block or a 1/0 "T" from that 1/0 coming off your existing terminal to the alt and you 'll be cool mang.
I got banned for being an ignorant ass....and im a dickhole
i like men, michael jackson and large sausages
That would Def work, but I dont have money to buy a battery right now :(
The 1/0 T sounds like a Great idea, never thought about it. Thanks.
But I guess my main question now is about the fuse/relay box and my stock wiring. Can I take all the stock wiring out and just replace it with my own 0 guage? and then just run an 8 gauge from the battery to the fuse box? Sorry if im being difficult, lol.
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
