2 6in Aero's Or 1 10in Aero port
Drillrig52
Box is going to be 6.5 cubes with 2 Sundown SA-15s. Using 6 or 10 inch pvc for ports. I want to make sure im not going to have port noise and I want it to get down LOW. The aero port calc is saying for 31hz to have 18.5 length on 2 6in ports. Or 20.5 length for 1 10in port.
Which do you guys think would be better?
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
Rockford R-Series Components up front
POS Kicker KS650 Coaxials rear deck
2 Sundown SA-15s
Alpine CDE-123 Head Unit
Custom Sub Box 5.8cubes 31hz
Efficientcy.... 1 10" aero gets my vote.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
At 6.5 cubes net? 1 10" would be better. Two 6" ports leaves you with about ~8" per cube. Ew.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
this
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
I believe 1 10in will give you 12in^2 per ft^3 of port area which in in the range of the regularly accepted 12-16in^2 but the 2 6" do not they are about 8in^2 per cube so I would go with the one 10"
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
You found 10" pvc?
You mean concrete former tubes?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Aeros usually go in the 9-12 in2 of port per ft. 12-16 in2 is for slot ports, and that's just a general "rule of thumb" of course it will vary....
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Oh I see I was mistaken then I was thinking that it was the same as slot ports. But still one 10 would work right?
That's a LOT of port. And like.. 3.5 ft long..?
Sub Amp: AB 450.1
XS D3100
Come on 150!
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
