Siren mounted pointing down? if its pointing up water could be in it.
Where is the siren grounded?
Edited by EVAlonSo
MECP MASTER CEA208509
Proud employee of Alarms, ETC in lakeland, FL
ASE certified
2002 Tacoma:
4 RF P3 15s @ 28hz
2 RF T1500-1bdcps
2 pair Kicker QS
4 Pair RF Power 6s
3 RF p400-4
1 RF p200-2
ALP CDA-9887
Exactly what he said you want to point them down if you can.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Also if it is a DEI based siren, you can cut one of the loops coming off the siren and it doubles the sound, I can't remember which wire it is without looking at one lol.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
the black wires that are looped, not counting the ground. and also point that sucker down
just check connections
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
And just a note cutting the black loop is only going to increase the chirp volume and not the full siren volume.
ASE certified
2002 Tacoma:
4 RF P3 15s @ 28hz
2 RF T1500-1bdcps
2 pair Kicker QS
4 Pair RF Power 6s
3 RF p400-4
1 RF p200-2
ALP CDA-9887
Sorry guys just got home from work. This was installed last year at bestbuy. a month after that I cut the loop to increase the warn away chirp as I use the motion sensor and it was installed firing down. I'm starting to wonder if this car is getting long in the tooth. I had to pull the car horn fuse because if you pushed on the button just to sound the horn it would sound like a dieing horn whimpering out. Since the 5901 is linked with the car horn say the full alarm trips it sounds lower than usual and with a whimpering horn along with it lol.
As for the ground it would be where ever the installer put it at best buy.
Edited by crunkjuice1
you either have a bad ground, bad positive, or siren is going bad. best buy should warranty if its a wiring problem. let them figure it out for you.
ASE certified
2002 Tacoma:
4 RF P3 15s @ 28hz
2 RF T1500-1bdcps
2 pair Kicker QS
4 Pair RF Power 6s
3 RF p400-4
1 RF p200-2
ALP CDA-9887
I'll take a look at the spots the installer used to make connections. Now another question for 5901 owners or people with experience with it. right now your alarm is armed, say you to the car or just the window of your house and push the arm button on remote again how many chirps do you hear? I get two spaced apart. I know I can take it to have them tinker with it but I'm trying to rule out anything my dumbass could have done lol
v
  • Who's Online   0 Members, 0 Anonymous, 1832 Guests (See full list)
