my explorer is sagging in the rear from my system weight and i was wondering if this is what i need or if anyone has a better idea
http://www.sdtrucksprings.com/hellwig-helper-springs/ford/explorer
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Better idea`s? Aw yeah 8)
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
If you were to just use an add a leaf it would help with the sag it will also make the leaf pack harder in the sense that it won't give as much. That or if u used lift shackles to lift the rear up a little more then stock. Lift shackles will add as much as 2 inches of lift in the back, and the add a leaf will also add about 2 inches of lift. If you want more info on your truck you can also check out this website www.explorerforum.com
wouldnt adding blocks lift it up alittle?
maybe air shocks, not sure how much that would lift it tho
changing out that rear shackle for the leaf spring might lift up alittle aswell
just some ideas, this is what i was gonna try in my jimmy but never got it
On explorers its spring under so blocks would lower the truck. If u wanted to do blocks u would have to do a spring over conversion and that alone will take u up 5.5 -6 inches in the rear
  • 5 weeks later...
