If You Want Enclosure Plans Then Here Ya Go!
andym85
i am wanting a box design for a 2003 tahoe.box dimensions would be 48w by 26 to 28 deep h im not sure about.i am wanting enclosure to be 13 cubic ft internal with a 200sq inch port tuned to around 35 hz subs up port back.it is for 2 18 treo ssx.that 13 cubic ft would be after sub displacement and bracing.sub displacement is 0.31ft per sub thanks
idk..that MIGHT work...depends on if the inner flange would hit the subs. i know the outer flange on aeros is 7.25"...and the inside is a bit smaller, maybe 7"...i really think that would be cutting it close b/c u only have 12.5" of height on the inside...that sub is 6.5"deep and then take into that 7"flange and you are at 13.5"...just dont think you have enough height...
damn sorry for the headache..what about dual rear side slot ports?
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
dont think its gonna happen...
internally you have 28.5"of width...probably about 25" of that will be taken up by two 12's (whose outer diameter im assuming to be 12.5")...which leaves you with 3.5" for your port width.... .75" of that will be taken up by the wood used for the port which takes your width down to 2.75"...way to small
i likes me some audio stuff...
Alright, also is the port length 8"?
see on the bottom left side...under round port dimensions...it says port length? ;) 12" long for each port ;)
Posted Image
you guys need to really thank amatt....he has spent a ton of time doing these plans.
what program is that you use,amatt?
2002 nissan frontier crewcab
eclipse cd2000
mb quart prem's fr&rear
rf p4004
ty man!
for the drawings it is just google sketchup....and for the number crunching i use an excel spreadsheet that i made...
I made sure to thank him properly!!! :D:D:D
he sure did!! :)
I guess the only way is subs up and port back huh?
PS
or 2 subs up and 2 subs facing back?
TEAM DEADLY HERTZ
