If You Want Enclosure Plans Then Here Ya Go!
andym85
its for a 15" HDC315. and its tuned to 32 hz but i messed up the box. hopefully it still sounds good.
ok so size wize its ok, how do i make it tunned to 37 hz, i can just use the same type box as urs, but just make it tunned higher...how do i go around doing that? make port shorter or longer?
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Hey bro i kinda fucked up on cutting the wood and cut the front and back 1.5"s too tall. i would end up putting the front and back on the outside the box not inside. now if i moved the port up .75 i would have 1.5 more inches from the back wall then what i did before. how much would that effect my tuning? does that make sence? lol
just make the length of the wood for L2 1.5" instead of 6"...
i likes me some audio stuff...
Alrite fellas, I have a request. This is going in a 1998 Ford Explorer. I would like plans for 2 Cerwin Vega V-Max 15"s. My max dems. are 41"W x 18"H x ?"D. Whatever it take for depth to get the right airspace. It is recommended they have 3.5 cu. ft a piece. Tuning is 35 Hz. Specs show you what you should need. All fire to the back. No bracing. Thanks, you da man! Oh and please slot port me, I don't want no tubes.
2012 Honda Accord
Radio: Pioneer AVH-4200NEX
u know what, it may be....there are no box recommendations for mt's so i kinda just went of specs for the btl which is 3-5cubes....u want me to re-do it and knock it down to like 3.5 or so per sub?
yes if you can i just want something that will get loud and low daily with 2000watts daily soon to be 4000watts daily
1995 acura integra gsr
pioneer deh-p 7700
massive audio d400x
1 re mt 12
0/1 wire
2 yellow tops (for sale)
