If You Want Enclosure Plans Then Here Ya Go!
andym85
Hey i pm'd you about that box design, well I've been thinking and this will be easier, that and I actually have a car now.
Two Dc level four 12"s
Daily/kicker zx1500.1
1996 Cavalier Coupe
Max Dimensions
Height=15"
width=34"
depth=30"
Instead of the two seperate chambers just one for both woofers, but i want a divider between them so the cones don't work off of eachother and just the the back walls 45'd.
1996 Cavalier Coupe
Max Dimensions
Height=15"
width=34"
depth=30"
sorry man....its hard to keep up with them when i get them via pm...not sure what u wanted it tuned at, so i just did 33hz....here ya go
Posted Image
Posted Image
Posted Image
i likes me some audio stuff...
actually bro dont mean to be a prude but do you think you could get me a cut list down? im not sure what the measurements of the port are. btw i tossed you some change for your help, thanks again.
port measurements can be found in the spreadsheet i post..."length of wood for L1" and "length of wood for L2"
i normally dont do cut lists, but i guess i will
top/bottom: 16x30
sides: 16x15.5
back: 15.5x28.5
front: 26 1/8x15.5
port
L1: 15.5x12 1/8
L2: 15.5x6 9/16
top/bottom: 16x30
sides: 16x15.5
back: 15.5x28.5
front: 26 1/8x15.5
port
L1: 15.5x12 1/8
L2: 15.5x6 9/16
sorry bout that i just needed the port dimensions i didnt look on the spread sheet for it my bad.
Can Amatt or anyone else help me with the the dimensions of the port wall? I don't know how to read it to know what the cut pieces will be. It's the on for the two DC Level 4's.
its encirlcled....and i actually think i just made L2 1" in the drawing....instead of .875...
Posted Image
-max dimensions----------------------------------------------------- 30 l x 41 w x 22 h
-type of subs--------------------------------------------------------- (4) Kicker CVX 15's
-number of subs------------------------------------------------------ 4
-desired tuning frequency--------------------------------------------31-36 hz
-type of vehicle--------------------------------------------------------2004 Ford Explorer
-position of the subs and port----------------------------------------subs facing up and port to the back
I want this to be a spl setup but I will also be playing music and movies with it also. If you could help me I would really appreciate it.
i cant get all of the subs to fit on top b/c your depth is only 30"....
