If You Want Enclosure Plans Then Here Ya Go!
andym85
-max dimensions----------------------------------------------------- 17 l x30w x 14.5 h
-type of subs--------------------------------------------------------- BTL 12 / Daily Driver
-number of subs------------------------------------------------------ 1
-desired tuning frequency--------------------------------------------32 hz
-type of vehicle-------------------------------------------------------- Acura Integra Sedan
-position of the subs and port----------------------------------------subs/port back
Also i would like to have it double baffled.
Thanks!!
Posted Image
Posted Image
i likes me some audio stuff...
menace89
this will work for both type subs...and its a fucking tight fit!!!!
Posted Image
Posted Image
Can I do a square port in the middle of the top 2 subs? hopefully it wont be as tight of a fit. <_<
maybe...i will look at it tonight...just not sure if i can get enough port area that way...
I just looked at it and i can fit a 12"x12" port...that should be good since its 144 sq. in. of port right? If thats good, is the length still gunna be the same?
Could you design a box for my Digital Designs 3515d, 4cubic feet net tuned to 37-38hz using aeroports sub foward port up. Max dimensions are 36W 24H 13D for an X-cab S-10. Thanx
TDH FTW !!!
can you give me a port size? the inside specs are
29" 3/4 tall
39" 3/4 wide
22" long
tuned to 32 hertz
can you also let me know how many cubic ft. it is? this is for 2 18" btl'z
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
menace89
Posted Image
I was lookin at this and saw that u put 1.5" for wood thickness so it took off 3" off of my max dimensions...its already kind of a tight fit with .75" wood, so theres no way it'll fit with 1.5" wood :lol:
So as long as I make my box 14.383 cu. ft. before any displacement, it should be fine right?
