well i have this amp http://www.sonicelectronix.com/item_23875_MB-Quart-ONX1.1500D.html#tabs and pulled the trigger on the 4ohm sa-12 figuring if i have room in the future to add another, but were talking 6-12 months, it is going to be "professionally installed" and tuned as i don't want to have to deal with all the electrical components of the bmw.
the specs say
1.75 ft^3 ported tuned to 30 Hz -- F3 of 26 Hz
* Tune higher and use a smaller box for more SPL oriented setup (Use 1 - 1.5 cubes)
* Enclosure can be as big as 2.25 ft^3 with lower power levels
so if say i found a box like http://www.sonicelectronix.com/item_19279_Sonic-Sub-Box-1SV12-Black-Carpet.html
says 1.8F^3 would that be good? or do you recommend something different for 1k w?
the specs say
im guessing youre wiring it to 2ohms. and i doubt that amp will put out the 1k its rated at. i would wire it to 1ohm with that amp if you havent gotten the sub yet and build a box at around 1.5-1.75 cubes. sa's can take the heat like no other
Edited by fmedina
You could always upgrade to the spl coil
i wouldnt recommend the SPL coils if hes looking for more of a daily applicaton
and OP, IMO your best bet is to build your own box from a proper design, that'll give you best results
i had my pair of SA12s in boxes ranging from 3.5 cubes, up to 4.6 cubes on my saz3500d @ .5, daily without any issues, so box size can be as big as 1.75 up to about 2.25 or so
my girlfriend has a single sa12 in her car on 1000w in a box thats 1.97 cubes tuned to 33hz, its actually on the mbquart 1000.1, the smaller version of the one you linked:
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
then again this is one of those "if you need to ask" situation. if you dont have experience with overpowering a sub then i would recommend not giving it more than 850rms
well i already had the amp thats why so i was wondering if the sa-12 could take 1000w because it was on sale and fit the budget i was in, and the main reason i heard all the good reviews on it and how it had underrated rms power
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
