boss cx10 cabinets
I made a pair of speaker cabinets with a realistic piezo and a boss cx10. they sound great but
one of the cx10's starts to smell and get hot after one or two songs while the other stays cool.
they are both getting the same power. whats the problem???
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Cool.. do you have more detial on what you done besides boss subs(idk bout them boss subs)
wireing? power source? subwoofer voice coil ohms?
they are 4 0hm, 300 watts rms, i am running them off of a pioneer vsx-3800, a little older but it
gets the job done, the box's are about 1.2 cubes, single voice coil subs. as far as wiring i have the tweets and the subs wired in parallel to a speaker terminal. like i said they are each getting the same power yet one sub is smelling and getting hot. thanks
Pioneer HU
sound like bad sub .. so you have the mids/hi's all wired together with the sub? if so you may be presenting a very low ohm load to the receiver causing it to clip or out out to much power for the sub to handle..
You'd . need a crossover to get the subs with mids/highs connected together at the terminal and you would have to be sure that all the ohms are correct for the reciever/amp. i think you need to stay above 4 ohms at the terminals (idk)
double check your wiring
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
you know, i think you are right. 2 4 ohms in parallel is 2 ohms and i dont think the receiver is made for that low of a rating. but i am wondering why only one sub does it.
Pioneer HU
Problem
so woofers and tweeters are both receiving full range signal? Yeah...that's a problem
ya i am going to hook up a crossover network. that should help
Pioneer HU
Problem
One woofer gets hot and smells while one does not. both getting the same power
Pioneer HU
