w87will Posted November 19, 2007 Report Posted November 19, 2007 Which would work better? Also the recommended Thickness. Quote
Amalan Posted November 19, 2007 Report Posted November 19, 2007 id say acrylic look at some of the acrylic boxes that gately audio has done http://www.stevemeadedesigns.com/board/ind...?showtopic=6947 Quote
w87will Posted November 19, 2007 Author Report Posted November 19, 2007 Any Idea on thickness? its going to be a smaller window, 9" x 24" is the max dimensions of the glass. Quote
w87will Posted November 20, 2007 Author Report Posted November 20, 2007 Im planning on Buying the plexi soon to start my box. What thickness would work out? Im thinking 1"...but if alittle thinner works that'd be great. Quote
mrwigglezdj Posted November 20, 2007 Report Posted November 20, 2007 for a window of only 9 in height i would go 1/2 inch 1 inch is real extreme for a window.....save some major money and go 1/2 Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
w87will Posted November 20, 2007 Author Report Posted November 20, 2007 for a window of only 9 in height i would go 1/2 inch 1 inch is real extreme for a window.....save some major money and go 1/2 Yeah Ill def save some money going thinner...thats Why I wanted to see what would work. So I shouldnt have any problem with 1/2? also I was reading about the polycarbonate lexan.....it was saying its stronger than acrylic. Should I go 1/2 Polycarbonate or just stick with acrylic? Quote
David Posted November 20, 2007 Report Posted November 20, 2007 use the same thickness as the other material ur using to build the box. 3/4 mdf I would use 3/4 plexi. Quote
w87will Posted November 20, 2007 Author Report Posted November 20, 2007 use the same thickness as the other material ur using to build the box.3/4 mdf I would use 3/4 plexi. That might make it alittle easier to have it flush with the face of the box. Quote
Amalan Posted November 20, 2007 Report Posted November 20, 2007 That might make it alittle easier to have it flush with the face of the box. thats going to be really hard to cutout fyi i would just stick with a window it would give it more support Quote
w87will Posted November 20, 2007 Author Report Posted November 20, 2007 thats going to be really hard to cutout fyi i would just stick with a window it would give it more support ?? It'll be a window still. If I use 3/4 plexi I just have to cut the size of the plexi out of the box and it'll fit right in there flush. Then Ill use some strips of wood on the inside and screw/glue them so its about an inch on the plexi and on the mdf to support the plexi. also screw the plexi from the outside to those strips of wood. Thats the only way I figured it'd work. Anyother suggestions? Quote
