~ iPad inDash SQ Rebuild ~ Scion tC 2006 Old Alpines, Sundown, Pioneer, Mechman
The kickpanels turned out great, and the vinyl looks like it matches very well with your interior, though I'm excited to see those Z v3's soon, should be epic.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
thanks can't wait to get them in, worked almost 70 hrs last week to pay for them lol! You got a PM btw
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Just wanted to copy this here bc Omega asked about glassing
since you're painting it's alot more work bc you want to get the surface super smooth.
Head over to sherman williams and find out where their autobody store is that has all the body work material
what you need:
  • Resin/polyester or epoxy works I like epoxy resin but its much more expensive
  • Fiberglass mat, nothing super thick if you tell them what you need they'll kno
  • Light weight Body filler (NOT BONDO) its going to look like this
    http://www.evercoat....ail.aspx?pID=11 that's what I use or this
    http://www.jamestown...ct.do?pid=10334 Cheaper but just as good
  • 1" and 1.5" and 2" brushes to apply the resin
  • Throw away gloves protect your hands
  • A mask for cutting the mat and apply the resin
  • Fleece to wrap your thing (NO COTTON lol it sucks)
  • CA Glue, hot glue, or staples to hold stuff the foundation and the fleece
  • Sand paper (Use an orbital or palm sander saves you LOTS of time)
    Grit 40 or lower to begin with I like 24-30 if you're using your hand
    Then move to 100. Gonna apply body filler here and smooth it out. Then go to 150, 220, 600, 800, 800 wet, 1500 wet to finish.
  • Take your time to figure it out
Goood luck man! Read over my thread and it's basically all the steps there
Scion tC SQ Build
Just to add a couple of tricks when finishing the glassing.
Oh and to add when you're frustrated or sanding or just want to see it in one color instead of filler/fleece/mat spray a coat of primer on it, it'll show you where you need to sand then continue sanding that area until the primer is gone, that will assure you a smooth finish. Another trick is to use filler primer which helps the pin holes. Then sand it back smooth, I waited to lay a coat of actually paint until it was super smooth after the primer and a wet 1000-1500 grit sand. Then paint and clear coat as much as ur heart desires until you get the finish ur looking for.
Scion tC SQ Build
it looks good down there but i would'nt wanna do that cause what if one of your friends kicked them?
you tell them to get the fuck out. Thats what i did
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Or I have em buy me some new 6.5 comps :)
The kicks them selves are very durable so I can't imagine them breaking but u never kno
Scion tC SQ Build
  • Who's Online   0 Members, 0 Anonymous, 1632 Guests (See full list)
