I love to lie in order to make people like me
My trunk isn't stock...
... I double layered my trunk floor with dynamat, there's a single layer on my lid ( my previous trunk had 2 layers, but I broke that bolts and the welds... ) - I just haven't dynomatted the sides of the trunk yeah ( that would completely enclosure it... And I didn't spray expanding foam inside of my lid...
... But I am going to buy a new trunk w/ new bars, get everything welded together ( cause the factory bolts aren't working ) - I might even try " hood pins " and apply them to the trunk ( like racers use for their hoods ) - Just for extra downward force.
The system I started having broken trunk problems was with:
... (2) 12" Kicker CVXs - Power Acoustik STAX 5500/1D
Vehicle: 1999 Nissan Sentra GXE 4-Dr
Head Unit: Alpine CDA-9852
Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
Sub Stage: (2) 12" Lanzar OptiDrive 1232s - Custom Ported Enclosure: 6.81cuft Tuned @ 32Hz
Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
Processors: Clarion EQ-746 & Clarion MCD-360
Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
Batteries: (3) EverStart Maxx's ( 750 CCA ) 1 In Front & 2 In Back
DJ's Audio Installation
I thought you were meaning the trunk itself...
... Well if that's the case, yes - I have a stock trunk...
I know I could hit 150 easily if I were to face everything towards the cabin and seal it all off with the same setup I have now * Adding the 150A alt... *
... I already have the box plans for that...
This is a 2-pc Enclosure... Tuned to 33Hz
This is the front piece ( that goes in between the rear struts:
This is the rear piece that's the MAXIMUM dimensions for my trunk ( the dimensions of the sub enclosure I have now... 38" wide x 14.5" high x 25.75" deep:
Just another look:
Why is that? Everything will be sealed off from rear...
... Or are you talking about the common port?
lol 150 from a trunk.. u need to be in the local comp book then..and wtf on the sub baffles??
looks like you love that kicker audio..sad bc there are soo many better conpanies..
I do like kicker... And yes, I know there's better companies out there - But Kicker hasn't ever done me wrong thus far.
... And 150 from the trunk isn't impossible... Maybe 5 years ago, but no now.
And the what's wrong with my baffles? - I don't see any interference happening.
.. The lips are only .75" - that's so i can screw onto the 2nd piece of the enclosure...
What subs, amps, and electrical you gonna run.
And did you have trunk problems because of the massive dent
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
