varietyguy Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) I'm doing my build right now. running both amps at .5 1 amp to each sub in a single chamber box. Should I strap them together? If so how do I do it? Edited December 5, 2011 by varietyguy Quote 1992 Mazda 323 http://www.stevemead...323-wall-build/ Link to comment Share on other sites More sharing options...
Integra_boomer Posted December 5, 2011 Report Share Posted December 5, 2011 I'm doing my build right now. running both amps at .5 1 amp to each sub in a single chamber box. Should I strap them together? If so how do I do it? I believe its called a daisy chain? idk but shouldnt be too hard, but i only have one saz3000 so not really sure how to do it. Quote 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s Link to comment Share on other sites More sharing options...
fritosaregood Posted December 5, 2011 Report Share Posted December 5, 2011 I'm doing my build right now. running both amps at .5 1 amp to each sub in a single chamber box. Should I strap them together? If so how do I do it? I believe its called a daisy chain? idk but shouldnt be too hard, but i only have one saz3000 so not really sure how to do it. wow, what a pointless reply.. its called strapping, not daisy chain. but what youll do is run your rca signal to the master, then run the signal from that amp using the BR OUT rca jack and connect it the the BR IN on the slave. then connect the negative speaker terminals on the master to the negative speaker terminals on the slave. the positive speaker connections on the master are the new positive speaker terminals and the positive speaker terminals on the slave are the new negative speaker terminals. I would strap then to simplify tuning. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
zayres29 Posted December 5, 2011 Report Share Posted December 5, 2011 its in the manual how to strap them and i wouldnt recommend strapping at .5 ohm your final load for a strapped pair should be 2ohm especially if you dont have any experience strapping amps in the past Quote Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
jakobebassbudds Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) wow triple post that wasnt correct info haha but good explanation tony Edited December 5, 2011 by jakobebassbudds Quote 2 12ks and i dont know what to do build in the works! Link to comment Share on other sites More sharing options...
