Popping noise from speakers when brakes are applied
As the title says i have popping noise from speakers when brakes are applied. I checked whole installation but everything seams fine. What makes that irritating sound?
Loose connection somewhere. Double check all of your sub wires / speaker wires both going into the speaker and out of the head unit / amp
Then check your power and ground connections
Also check your RCAs if you use them
^^^^^this
But also check fuse holder connections they are notorious for loose or bad connections. Look to make sure everything at the fuse holder connections are all flat and tight, i've seen them be really tight just not completely flat and that will cause problems.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I double checked everything, everything works fine, even at max volume. The pop sound is present also when I put in reverse when the engine is running. Do you think that light relay may cause this?
I've actually been having a similar problem that was getting worse and worse. It started out as a whining noise that went up in pitch with the RPM of the engine. It would get really bad sometimes and I could feel it from my subs. I've narrowed the source of the problem to the head unit, as the noise varies depending on the source (CD, Aux, USB, Radio). I pulled it out of the dash to check my connections and it got much better, like it was before with just a subtle whine. I still haven't figured out exactly what it was, but at its worst, I could tap my brake and make the speakers pop, too.
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
Do you own a pioneer?
If you're talking to me, yes.
Cadence FXA1600.2
Cadence S2W10
this, the infamous pico fuse
also, are you running them off the h/u? or off an amp? change your ground, or if your using your h/u ground your h/u with a star washer and a self tapping screw insted of just hooking it up to the wiring harness
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
It's a fuse?
I'm running everything off a dual amp setup. I checked my ground and it SEEMED fine...but I could try a different location just to see if there's a change. My head unit ground is hooked up to the wiring harness, but the connection is pretty solid...of course I don't know what ground the factory harness has. I'll check it out. Thanks for the suggestion.
Try grounding the outer ring of your rca's to the chassis of your h/u this usually corrects the issue
I know this probably sounds stupid, but how to you ground the RCA's?
Cadence FXA1600.2
Cadence S2W10
