This is how it should look if you have a front and rear output on your HU.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
one think you may have to do is buy a short wire of the wire your 4 channel takes...no sense in trying to shove wire in there thats way bigger than what it accepts
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
sigh, your going to 5000000 things at once, first off, as stated, you need a front/rear out put on the headunit in order for the 4 channel to work properly ( the front/rear output would hook up to the 4channel, the remaining(sub output) would be going to the sub amp) now for your power wire, use a distrobition block to SPLIT the power wire into 2, one goes to the sub amp, the other goes to the 4 channel, for your remote, just have the one coming off your headunit into the sub amp, then take a smallwire put it with that remote wire, then put the other end into the 4 channel amp, as for the ground, just ground to the same spot as you grounded your sub amp
think i covered all of it, any other questions feel free to pm me
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   0 Members, 0 Anonymous, 734 Guests (See full list)
