disturbed471985 Posted December 8, 2011 Report Posted December 8, 2011 I am about to buy some speakers and I have the following wiring option either a .67ohm load or a 1.34ohm load. My amp is a DB Drive A7 2000.1 and is rated at 2k@1ohm. Would it be best for me to go with the option to wire amp @1.34ohm or will wiring the amp at .67 be ok? I would think .67 would be fine as with box rise and all I will be well above a 1ohm load. What do yall think? I would like to get as much out of the amp as possible but I want to do it safely. I have that electrical to support the amp 180amp alt and 1 group 31 as well as the starter battery.
Bakerman Posted December 8, 2011 Report Posted December 8, 2011 I would think .67 would be fine as with box rise and all I will be well above a 1ohm load. Thats what I would guess...I'm sure it will be okay under 1ohm anyways.
RooTxBeeR Posted December 8, 2011 Report Posted December 8, 2011 ^^x2 just be careful when your first use to see if it can run it safely, check to see if it gets really hot and what not. If it can't run it, You can run it as 1.34 Ohms then, which with rise, you'll prob see 2 Ohms. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
disturbed471985 Posted December 8, 2011 Author Report Posted December 8, 2011 ^^^^ thats the issue it is either or If I run at .67 ohm I will be buying 3 dual 4ohm subs if I run at 1.34 I would get 3 dual 2ohm subs. So once I buy there is no turning back.
RooTxBeeR Posted December 8, 2011 Report Posted December 8, 2011 With the dual 4's you have the option of 2.7 ohms, and the .67. As for the Dual 2's you got 1.3 and 3 ohms. I don't got enough experience in this anymore to help you out more than I have, gl though on getting it all to work out. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
bassahaulic Posted December 8, 2011 Report Posted December 8, 2011 The A-side amplifier will run below 1ohm with ease. I had two A7 1,500's running at .4ohm each daily. Never had issues.
disturbed471985 Posted December 8, 2011 Author Report Posted December 8, 2011 The A-side amplifier will run below 1ohm with ease. I had two A7 1,500's running at .4ohm each daily. Never had issues. Appreciate it..
