bumpinTL364 Posted December 8, 2011 Report Posted December 8, 2011 I know that most shelf speakers that you can buy all tabbed up have some amount of porting done for the mid-range to get it to blend better with the subwoofer. I'm already going to be using a 12" in a t-line for the room setup i will be running, but I need to know if I should build ported or sealed boxes (and how big they should be) for the coaxial drivers i'm going to be putting in my room. They are Aura 4000RPM 4" coaxials, they reach down to 45hz so i feel like i should do something to take advantage of that lower range there, but I'm not sure how to design a box properly because they don't give thele-small parameters or anything else i could use to figure out tuning....help please??? masterbation is free, and even saves you money.sorry but someone had to say itsorry, Jimmy...beat you to it (no pun intended) LOLDON'T get a wife. Best advice I never got, and now it's too late My build: 12" DCON in a dorm room. New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
cvxsmitty58 Posted December 10, 2011 Report Posted December 10, 2011 personally with a 4 inch speaker i would go sealed. You may not have the output of a ported enclosure but the speaker should still play fairly low regardless. Chances are you arent going to get a ton of output at 45 hertz with a 4 inch coax.
412 CVX Posted December 10, 2011 Report Posted December 10, 2011 look at this site. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
bumpinTL364 Posted December 10, 2011 Author Report Posted December 10, 2011 sweeeeeeeet find! thanks very much! masterbation is free, and even saves you money.sorry but someone had to say itsorry, Jimmy...beat you to it (no pun intended) LOLDON'T get a wife. Best advice I never got, and now it's too late My build: 12" DCON in a dorm room. New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
