BassMunky Posted December 9, 2011 Report Posted December 9, 2011 anyone know how to accurately set a amp? like how do i get the amp to acc read 80hz on the lpf and on the ssf to read 30hz since my box is tuned to 35hz? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 10, 2011 Author Report Posted December 10, 2011 bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
miniSPLlancer Posted December 10, 2011 Report Posted December 10, 2011 you should be able to see numbers in DB's on those adjustments. If you want to set lowpass to 80, your subsonic should go from 10-50, so usually 30 in the middle 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
magillaru Posted January 11, 2012 Report Posted January 11, 2012 Most amps should have numbers listed in intervals and then just estimate where you want it based on those numbers... Singer Alternators Team Asshole #anothershittysingerbuild
