I hadn't hooked my bassknob into my amp since i was unsure on how to use it. Should i plug the knob in first then set my Gains or set them and then plug it in? and should i have the knob turned all the way to max while i'm setting them?
Edited by TygaTony
turn them half way on the remote and set your gains with the dd-1. It says that on the dd-1 manual but i turn my knob 3/4 and set my gains.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
Most bass knobs are basically gain knobs, so take notice where the gain gets set on your amp cause when turning up the bass knob you won't notice any gain in sound once the knob goes past the point the gain is set on your amp.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
i useally turn mine 3/4 of the way up then tune my amp....but i am not 1 to turn my stuff all the way up :pardon: i have never had a issue doing this and have even got excited and cranked it all the way up and it was fine...def wanna have that thing hooked up when u set ur gains tho
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
That's because once you turn the bass knob past the point at which it's set on the amp, it doesn't do anything.
  • 5 weeks later...
