So I get that you have your sealed, ported, and all those assorted kinds of bandpass boxes.....but what is the real difference in them? I understand sealed is better for sq and a ported is better for spl (anything really cause u can tune it to whateverthefuck you want) and idk how a bandpass compares to either of those. Can anyone tell me what the different is between these and what's best for staying loud throughout the sound spectrum? Sorryyyy....feeling like a super noob for this question, but this has always confused meee.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I might be wrong, but this is how I understand it
Sealed is usually for applications that don't have space for a ported box
Ported will be louder than a sealed box, keeping similar sound quality
4th order will get slightly louder and lower than ported, but at the sacrafice of some sound quality (but this can be designed around) and is slightly larger than a typical ported box
6th order will usually be the loudest, but has the least sound quality. It is also the biggest of the bunch
T-lines are good for sound quality but they take up tons of space
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
Thank y'all, but what's the difference between sq and spl?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
sq is sound quality: designed to have a tight, flat response with minimal distortion
Spl is sound pressure level - aka loudness. That is about efficiency and power handling to get as loud as possible, accepting that there can be some distortion in the bass
As your box gets more complicated you can get more complicated results.
Simply put, if you want bass put it in a box and boom away.
If you want more bass, and have learned enough you can make a ported box that tailors the woofers output to your desired taste. (using variables such as woofer, box volume, tuning freq, and port size)
If you build bass ass ported boxes and you are getting beat by equally badass ported boxes you can go bandpass which gives you even more variables for a desired outcome that has the greater potential to be louder, as well as having an equally high chance of failing epicly.
using parallel or series tuned 4th, 6th, and 8th order bandpasses you can be extremely precise with the output whether it be flat or a one note spike. For the majority of people out there a sealed box is perfectly fine. For some, like the members on this forum, ported boxes add that bit of edge and satisfies the boom itch. For a few the pored boxes get old and boring and they venture into ABC boxes, Tlines, and Bandpass boxes. Can they be better? yes. Can they end up worse? yes. Are they worth the time and effort? Depends on how much time and effort you have and if you are a bass crackhead or not.
/ rant
-Drew
uhoh_45 said:
  • Who's Online   1 Member, 0 Anonymous, 1673 Guests (See full list)
