TigerTony Posted December 19, 2011 Report Share Posted December 19, 2011 My first question is that, I'm making a Box for a DC level 3 15" I'm buying from a guy that's local to me. I got these specs all out and then did a quick sketch of it in Google Sketchup. How does it look for Sub up port back since it'll be in the trunk of my 98 Buick Century. I wanted to make sure i had these right before i started it up. Box Material Questions: 1) How would Titebond 2 Be for building the box and then sealing the corners of the box and stuff? My dad has Gallon's of it and i was wondering how well it would be. 2) how long/ What kind of Screws would i use to screw through the MDF or should i just leave the it alone with lots of glue? 3) What are alternatives to Covering the box? 4) If I were to use the Titebond on the interior "seams" of the box and then wanted to Put something else over the rest of the MDF what could i put? Quote Link to comment Share on other sites More sharing options...
Sid420 Posted December 19, 2011 Report Share Posted December 19, 2011 3) you can paint the box, you can carpet the box, you could cover it in vinyl. 4) for the rest you can use fiber glass to get it all smooth. If that's what you mean. Quote Link to comment Share on other sites More sharing options...
xterraboy03 Posted December 19, 2011 Report Share Posted December 19, 2011 Inch and half screws, titebond will work great, and use rhino line from walmart looks great and its cheap! Quote 03' NISSAN XTERRA (1) AQ3500d (1) AQ4x90 (1) Audio Control Line Driver (4) DC LVL 4 15's Cresendo Mids and Highs 100' of 0/guage Big Three Mechman 270a Charging @ 16.5v (6) XS D1400's Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1 Updated JUNE 2012*****MY BUILD LOG USACI REGION 6 POINTS LEADER 2011 USACI KANSAS RECORD HOLDER 2011 Team DC http://www.dcsoundlab.com/ Link to comment Share on other sites More sharing options...
TigerTony Posted December 19, 2011 Author Report Share Posted December 19, 2011 Thanks both of you! Any words on the Box anyone? Also, Where might i be able to get Fiberglass and how would i do it? Quote Link to comment Share on other sites More sharing options...
2007TBSS Posted December 19, 2011 Report Share Posted December 19, 2011 I used the Rustoleum Texture paint with Rustoleum 2X cover gray primer. Quote JVC AVX840 Xtant 604x Xtant 403a 2 RE SEX12's Polk Audio DB6501 Front and back http://www.stevemeadedesigns.com/board/topic/127503-re-12s-box-build-system-complete/page__p__1794327__fromsearch__1#entry1794327 Link to comment Share on other sites More sharing options...
TigerTony Posted December 19, 2011 Author Report Share Posted December 19, 2011 I used the Rustoleum Texture paint with Rustoleum 2X cover gray primer. That Looks Really Good! is the Primer Mixed with the Paint? and if i wanted to, Would you say i could use that on the inside of the box aswell? Quote Link to comment Share on other sites More sharing options...
2007TBSS Posted December 19, 2011 Report Share Posted December 19, 2011 The lid of the paint made it seem like it would come out less gray and more black but I liked it anyways so I left it. The primer didn't show through at all. That's just the color. I got some button head screws and screwed them 1/4" into a strip of waste wood and painted the heads flat black for the port screws. Quote JVC AVX840 Xtant 604x Xtant 403a 2 RE SEX12's Polk Audio DB6501 Front and back http://www.stevemeadedesigns.com/board/topic/127503-re-12s-box-build-system-complete/page__p__1794327__fromsearch__1#entry1794327 Link to comment Share on other sites More sharing options...
TigerTony Posted December 19, 2011 Author Report Share Posted December 19, 2011 The lid of the paint made it seem like it would come out less gray and more black but I liked it anyways so I left it. The primer didn't show through at all. That's just the color. I got some button head screws and screwed them 1/4" into a strip of waste wood and painted the heads flat black for the port screws. I like that color a lot and i saw a store that my friend works at carries that brand. Do you Put two layers of Primer on then apply the paint? Quote Link to comment Share on other sites More sharing options...
fox_racin4 Posted December 19, 2011 Report Share Posted December 19, 2011 Box is a bit on the small side IMO id get the net volume up to around 3- 3.5 cubes myself Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted December 19, 2011 Report Share Posted December 19, 2011 (edited) box is a little on the small side maybe shoot for closer to 3 cubes net (after all displacements) and maybe a touch more port area per cube maybe around 14-16 ninja'd by a minute.. LOL Edited December 19, 2011 by aqsubowner1990 Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
