Where do you have the remote wire attached to? Do your amps kick off too? Those power connections at the back are lamesauce.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
All the connections are tight, but everytime I hit a bump or tap on the dash it kicks off or the lights go dim.. Wtf
So loose it physically by unscrewing and then tap it while on, if it still does that check the fuse if you installed it, if not then it's something inside it.
