Freshman6969 Posted December 19, 2011 Report Share Posted December 19, 2011 (edited) so, i got my mechman a few months ago, installed it after 5 hours of banging the old one out and grinding down the mounting feet on the new one to get it to fit(it was slightly off, bench grinder ftw) anywho....i have 2 xs d2400's backing up my DC3.5k which is wired down to .5, now for the annoying kicker...my jeep charges at 13.6, so cold startup im sitting 14.3 then it drops and levels somewhere between 13.9-14.1, after driving for a bit it drops down to 13.5, but kicks right back up once i tap the gas, BUT heres my problem, i drop to freaking low 11's full tilt, wtf? whats the problem here? i have 0g from the alt stud to the + on the batt, mounting stud to - on the batt, then - on the batt to the frame, now i cant remember if i sanded down where i put the ground on the alt, but i wouldent think that that could cause that huge of a problem, i also dident use the given lug for the + run that mechman provided, again i couldent see this as much of a problem, 3rd, i have my back batts running of the alt itself, youd think itd be a bit better, even with my amp running @ 2ohm i get roughly the same drop at full tilt, im mind boggled here, its a 270amp unit** 02 jeep grand cherokee laredo inline 6 Edited December 19, 2011 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Ray Posted December 19, 2011 Report Share Posted December 19, 2011 Wired to .5 yourprob drawing 325-350 amps and have a 270amp alt Not rocket science Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
Ray Posted December 19, 2011 Report Share Posted December 19, 2011 You said you didnt use the lug provided, so what did you use?? Guess you figured he adds it cause he doesnt know what he's doing. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
extremeauto Posted December 19, 2011 Report Share Posted December 19, 2011 (edited) i had to have my mechamn sent in for repair ...they said because i used the wrong size o ring terminal (lil big)it messed mine up...it did melt the plastic around that terminal...so i would check that a.s.a.p also you always want to take your grounding points to bare metal ...if you worried about rust spray paint after u tighten it down.... i would also take a ground from the frnt bat to the fire wall as well as the frame to fire wall...im guessing your running you other batts grounded to the body...more thing have you charged ur bats recently? Edited December 19, 2011 by extremeauto Quote 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing! Link to comment Share on other sites More sharing options...
tlee2 Posted December 19, 2011 Report Share Posted December 19, 2011 damn man... i ran my sundown 3500 @ .5 ohm with STOCK alt and 2 kinetik 2400s and couldnt make voltage drop below 12.1 just had the big 3 and 2 runs of 0 guage Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333 Link to comment Share on other sites More sharing options...
Ray Posted December 19, 2011 Report Share Posted December 19, 2011 Im guessing hes not actually charging The post is the only real output from the alt, so whoknows wtf hes got goin on Im suprised freshman... your not a newb here Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
Freshman6969 Posted December 19, 2011 Author Report Share Posted December 19, 2011 (edited) Im guessing hes not actually charging The post is the only real output from the alt, so whoknows wtf hes got goin on Im suprised freshman... your not a newb here im an electrical noob, thats my downfall, MECP my ass , i have 2 runs front to back 1 neg(off the front batt to the back batt), 1 pos off the alt, i think ill freeze my ass off tom. and find this lug and use it, unless my dumb ass used it for something else >.>, either way THAT lug will be going on the alt, ill be checking if i sanded down the ground point on the alt, if i dident, thatll be coming off, i have the batts grounded in the spare tire well also, i checked both grounds with a dmm and both read .01 so thats perfect, even when i was at 1 ohm with my other set of 15's i was yeilding roughly the same numbers as the .5 and 2ohm wiring also, anytime im not using my single plug outside the batts ARE infact on a charger, and all night before shows also @ ray, i used the lug i already had on all my big 3 wires, it fits on there perfect Edited December 19, 2011 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Jd1102 Posted December 19, 2011 Report Share Posted December 19, 2011 i think ray thought that you didn't use the post the copper lug was on. But extreme auto said that he messed his post on the alt up by using the wrong terminal like you might have so maybe you should look into that not saying its to late to fix but if your gonna change to the one they sent you might as well look at the post while you are there Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted December 19, 2011 Author Report Share Posted December 19, 2011 (edited) i think ray thought that you didn't use the post the copper lug was on. But extreme auto said that he messed his post on the alt up by using the wrong terminal like you might have so maybe you should look into that not saying its to late to fix but if your gonna change to the one they sent you might as well look at the post while you are there that was my plan, it just popped into my head after scrolling through youtube and seeing all these people running such small amount of batts and around the power i have and a 270amp alt and keeping in the low 13's full tilt, made me think, well shit i did something wrong here i mean my alts been in for awhile now, about the 2nd day after i got it, i might run to autozone and get it tested, if itll read that high, i know how some dont, maybe ill get lucky Edited December 19, 2011 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Jd1102 Posted December 19, 2011 Report Share Posted December 19, 2011 i think ray thought that you didn't use the post the copper lug was on. But extreme auto said that he messed his post on the alt up by using the wrong terminal like you might have so maybe you should look into that not saying its to late to fix but if your gonna change to the one they sent you might as well look at the post while you are there that was my plan, it just popped into my head after scrolling through youtube and seeing all these people running such small amount of batts and around the power i have and a 270amp alt and keeping in the low 13's full tilt, made me think, well shit i did something wrong here i mean my alts been in for awhile now, about the 2nd day after i got it, i might run to autozone and get it tested, if itll read that high, i know how some dont, maybe ill get lucky right on maybe do the autozone first if you can that way when you fix you could see how much better it gets Quote Link to comment Share on other sites More sharing options...
