miniSPLlancer Posted December 20, 2011 Report Posted December 20, 2011 Powerwerx.com 1/0 welding wire is heat resistant up to 105°c Weldingsupply.com welding wire is resistant up to 90°c KNU & stinger(HPM) are at 105°c Would the 90°c welding wire from welding supply be fine for my 4 runs and big 3. I've heard that the insulation need to be resistant enough to run near any heated engine areas so that wire doesn't melt or become compromised. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
ChevyBoy95 Posted December 20, 2011 Report Posted December 20, 2011 Powerwerx.com 1/0 welding wire is heat resistant up to 105°c Weldingsupply.com welding wire is resistant up to 90°c KNU & stinger(HPM) are at 105°c Would the 90°c welding wire from welding supply be fine for my 4 runs and big 3. I've heard that the insulation need to be resistant enough to run near any heated engine areas so that wire doesn't melt or become compromised. well thats 194°f, so I would say its fine, just make sure you put a wire loom or something around it just for safety. just try and zip tie or whatever you will do to it and keep it from touching anything really hot. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
miniSPLlancer Posted December 20, 2011 Author Report Posted December 20, 2011 Yeah my buddy has this like flex fit stuff that he puts around all the wire cable 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
POPLERO Posted December 20, 2011 Report Posted December 20, 2011 Aslong as it dosent make actual contact with anything hot in the engine I would image it would be fine.. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
Rickdod3 Posted December 20, 2011 Report Posted December 20, 2011 Unless its sitting on top of the headers it will be fine. No worries. Audio Technix Online Customer Service Specialist [email protected]
