Can I hook up my selenium st200 super tweeters to DD crossover instead of DD tweeter?
Or would I need to purchase a seperate crossover for it?
As of amp, 6.5 and super tweeter will be ran off sundown sax100.4D. ( DD 6.5 in the front and alpine in the back)
If their 2 way crossovers single input dual output ( one for tweeter one for mid driver )or a single crossover for the type of driver your using then yes
a crossover is a crossover, but the frequency range is what differs from different brands and models
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
yes, there is 1 input and 2 output's ( 1 for md other for tweeter).
How much power will they roughly see?
i think you need an 8ohm cross over
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
I talked to my dad and we decided to run left door ( DD 6.5 and DD tweeter) to 1st channel, right door (DD 6.5 and DD tweeter) to 2nd channel, in the back ( 2 alpine 6.5 @ 2 ohms) to 3rd channel and selenium tweeters we'll run @ 4 ohms with seperate cross over to 4th channel.
With this set up each speaker should see their rated power and seleniums will see 50wrms.
The rf crossovers has the bi amp capabilities with dual inputs and outputs iF you're looking for a good crossover
My dad is going to make me one
I'll take a look at rf crossover too.
It's all comes down to the price lol
Edited by LoudBimmer
