selenium st200 and DD crossover
If their 2 way crossovers single input dual output ( one for tweeter one for mid driver )or a single crossover for the type of driver your using then yes
a crossover is a crossover, but the frequency range is what differs from different brands and models
Edited by EBW
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
yes, there is 1 input and 2 output's ( 1 for md other for tweeter).
How much power will they roughly see?
i think you need an 8ohm cross over
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
I talked to my dad and we decided to run left door ( DD 6.5 and DD tweeter) to 1st channel, right door (DD 6.5 and DD tweeter) to 2nd channel, in the back ( 2 alpine 6.5 @ 2 ohms) to 3rd channel and selenium tweeters we'll run @ 4 ohms with seperate cross over to 4th channel.
With this set up each speaker should see their rated power and seleniums will see 50wrms.
  • Who's Online   0 Members, 0 Anonymous, 858 Guests (See full list)
