LoudBimmer Posted December 23, 2011 Report Share Posted December 23, 2011 Can I hook up my selenium st200 super tweeters to DD crossover instead of DD tweeter? Or would I need to purchase a seperate crossover for it? As of amp, 6.5 and super tweeter will be ran off sundown sax100.4D. ( DD 6.5 in the front and alpine in the back) Quote Link to comment Share on other sites More sharing options...
EBW Posted December 23, 2011 Report Share Posted December 23, 2011 (edited) If their 2 way crossovers single input dual output ( one for tweeter one for mid driver )or a single crossover for the type of driver your using then yes a crossover is a crossover, but the frequency range is what differs from different brands and models Edited December 23, 2011 by EBW Quote Kenwood KIV-BT900 Front Stage RF 400-4 Runs off dedicated 4 awg ofc RE 6.5 125.5. Lanzar Max Pro 6.5 Boston S60 6.5 components Rear Soundstream BX-15 Boston S60 6.5 components 4x Sundown SA8 v1.5 Crescendo BC3500D 2.4 net 28hz 4 runs of 0 gauge Big 3 HC2400 700ca up front Singer 350 Amp Alt No deadener :/ Scytek Galaxy Alarm Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 23, 2011 Author Report Share Posted December 23, 2011 If their 2 way crossovers single input dual output ( one for tweeter one for mid driver )or a single crossover for the type of driver your using then yes a crossover is a crossover, but the frequency range is what differs from different brands and models yes, there is 1 input and 2 output's ( 1 for md other for tweeter). How much power will they roughly see? Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted December 23, 2011 Report Share Posted December 23, 2011 i think you need an 8ohm cross over Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 23, 2011 Author Report Share Posted December 23, 2011 i think you need an 8ohm cross over so I would need another amp to run them? Or I can just hook them up to same channel with DD cross over Quote Link to comment Share on other sites More sharing options...
Decaf Posted December 23, 2011 Report Share Posted December 23, 2011 if the dd tweet was 4ohm, when u connect an 8ohm speaker the crossover point will drop by one octave. in other words, 4ohm@2500hz is 8ohm@1250hz Quote Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 23, 2011 Author Report Share Posted December 23, 2011 I talked to my dad and we decided to run left door ( DD 6.5 and DD tweeter) to 1st channel, right door (DD 6.5 and DD tweeter) to 2nd channel, in the back ( 2 alpine 6.5 @ 2 ohms) to 3rd channel and selenium tweeters we'll run @ 4 ohms with seperate cross over to 4th channel. With this set up each speaker should see their rated power and seleniums will see 50wrms. Quote Link to comment Share on other sites More sharing options...
speedball1978 Posted December 23, 2011 Report Share Posted December 23, 2011 The rf crossovers has the bi amp capabilities with dual inputs and outputs iF you're looking for a good crossover Quote Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 23, 2011 Author Report Share Posted December 23, 2011 (edited) The rf crossovers has the bi amp capabilities with dual inputs and outputs iF you're looking for a good crossover My dad is going to make me one I'll take a look at rf crossover too. It's all comes down to the price lol Edited December 23, 2011 by LoudBimmer Quote Link to comment Share on other sites More sharing options...
