I would use whatever brand primer matches the brand of bedliner.
If its rustolium bedliner, use rustolium primer. Sometimes mixing different brands of paint can cause a chemical reaction, so this is why you should use the same brand.
MDF will soak up paint like a BI*CH! The primer will act as a good first sealing coat, resulting in less paint needed.
Tho if the bedliner is thicker, it may not be too bad without primer.
I just did my mdf box with rustoleum bed liner (about 9 bucks a can) and did not use any base coat. I used about 2 1/2 cans for full coverage including port. This brand bedliner tends to be good stuff but THIN, which when I was planning on doing mine wanted thinker stuff. Either way I liked the stuff but since I kind of wanted more texture to it, I might stone coat it black a little later..
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
  • Who's Online   1 Member, 0 Anonymous, 1088 Guests (See full list)
