Well first we need the maximum space in which we can play with.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
oh yes of course. I just finished making some preliminary measurements:
length= 36 inches
width= 38 inches
height= 18 inches
These measurements are what I can fit as a right rectangular prism, but I don't mind using my entire trunk space and I can find a bit more if I need it.
should be plenty for a couple 12's. if someone wants to do the calculator work, i might be inclined to do a 3d model real quick.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I think that the unit for Vas is in litters on the Obsidian web page right? If thats the case I converted it to cubic feet and used the calculator on carstero.com to come up with the following values:
Drivers: 2
Qts:0.51
Vas:2.43
Fs:33
Vb:10.555
F3:22.02
Fb:25.41
To be honest these numbers don't look right to me at all; a Vb of 10.555 sounds way too large and a Fb of 25.41 Hz is lower then the manufacture recommends.
For a regular rectangular box I got measurements of 36w x 15h x 20d. Port Measurement: 4w x 13.5h x 19.4d...box tuned to 35hz. Total volume after speaker/port displacement: 4.062 *add a few baffles/braces...and it'll smooth that volume to 4ft^3
Was going to add an amp rack to the back, but the box may not be able to slide into your trunk if I did.
Edited by carshateme
Sweet! Thank you so much Carshateme. Are those box measurements the internal dimensions or the external dimensions (assuming 3/4 mdf)? Also what are the measurements of the rear port pieces and that triangular prism piece? Thank you again.
The box is measured from board to board...*just so you don't get confused* ex...the total height is 15"h...but the middle pieces are 13.5"..so external dimensions. MDF is 3/4" , front plate is flush mounted. Back port piece is 4.9 or 4 29/32" the long piece is 14.5". The prism piece is like one 2" long *middle piece* and 1 1/2" on apart from the middle piece...*two .75 cut together at a 36 degree angle.
I can do a layout on a full 3/4 MDF board and label them if you'd like.
