That seems pretty within my realm of possibility. Unfortunatly, there isn't much in there for mounging because its all cut out (which is why the springs were pulled in the first place) so I might have to get real creative with it.
-Drew
uhoh_45 said:
I just came back from a show today.
Newer Audiocontrol sealed on the dash on music did 148.6db
That is quite a bit considering I went from about a 141ish142 with 250w on the TL to 148.6 with approx. 500w
Good for a second place, the first place was four walled MOJOs with four big amps that did a 149.0 Not bad considering the power difference.
-Drew
Hot off the press.
-Drew
looks a lot better then the other aluminum trim
this is how i hold the trunk open- took some flat bar and bent it up to fit in the grove around trunk and it has a V at the tip to catch trunk lid
R.I.P!
(Nov-29-2009)
92 explorer
current build
Do you have any other pics? I'm having a hard time imagining how that works haha
-Drew
so i went out side (it snowed last night so had dust off trunk) took some pics came inside uploaded them just to find pics i had from before in same folder
and todays
R.I.P!
(Nov-29-2009)
92 explorer
current build
NOW it makes sense!
Im pretty sure I don't have any lip on the trunk arm to snag like you did. It just bolts into the trunk lid and its all smooth, nothing to grab. I use a piece of wood painted black as a "kickstand" between the trunk floor and the trunk arms.
-Drew
just throwing this out there trunks hurt when they fall on you haha thats why i came up with better idea then piece wood holding it up
R.I.P!
(Nov-29-2009)
92 explorer
current build
What has saved me before (ha) is I have a metal bracket that holds is place like a safety and the trunk will only half close while the safety is engaged. Granted, its heavy as shit and will knock somebody out on its half way down haha its better than nothing. The "safety" is also good for keeping the trunk open enough to see the amp but closed enough to keep the sun and nosy people out during shows.
-Drew
