Well, it started all bent up, rusty, missing bolts... squeeking when pushed... Well...
I decided to do a little work.. Did the best I could do to get the metal straight,.. Cleaned up the rust with chemicals, metal filled it down smooth, then hard sanded it smoother.. Dropped that primer on it, wet sanded it, dropped that crispy yellow base coat 3 times, wet sanded that, dropped that second 2 tone royal blue coat 3 times on that, clear coat wet sanded with 1200 grit and polished it. (cleaning with tack cloth and clay bar and all the goods inbetween coats..) Cleaned up tires.. and a few other things.. Then I added that extreme hardware:
New Grips
New Braking system
Blue LED Underglow (charged by coil/magnet system.. So when the tires spin, the LED's come on.)
New foot pad
All new bolts and screws, wd40ed up.
Sorry the pics are so small, I'll try to get some better ones later.
This was just a little project I did with a friend because we were extremely bored over brake... Should we add more? Horn? Motor? Idk?
Edited by TLEJ
I decided to do a little work.. Did the best I could do to get the metal straight,.. Cleaned up the rust with chemicals, metal filled it down smooth, then hard sanded it smoother.. Dropped that primer on it, wet sanded it, dropped that crispy yellow base coat 3 times, wet sanded that, dropped that second 2 tone royal blue coat 3 times on that, clear coat wet sanded with 1200 grit and polished it. (cleaning with tack cloth and clay bar and all the goods inbetween coats..) Then I added that extreme hardware:
New Grips
New Braking system
New foot pad
Winning!!!
Umm, put a horn on it. I wish you could do a train horn, but a little squeaker will work! Spinners!
1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire
*3 Kinetik 2400s and a Mechman 270A alt in the future*
I think a train horn would suit it well. Hahah maybe some tweeters on the steering column? There's a perfect mounting spot for some. Then maybe an Ipod holder..
(Jeez, this thing might be worth something after all..)
sweet!!
NoFearX18 said:
trainman0978 said:
lmao! Tweeters and a 3.25" Sub!
But yes, a little stereo type thing and an ipod dock would be sweet.
Edited by Ram1989custom
I still think you need some spinners.
Maybe a vroombox. :D
good work.. maybe the stringy tassles on the side of the handle grips??
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
