well i have a 1998 dodge avenger and i want to put some 20s on it my question is,
is it possible if so what do i need to do to the car to do it i would greatly appreciate any feed back.
2 massive DMX 12s
2 massive 1500.1
  custom ported 3.0cuft enclosure
1 old school mtx 800 4ch
2 kinetik 800 just added 2 more 4 altogether
1 kinetik 2400 (underhood)
1 3frad stinger cap (hate it)
big 3
0 ga wireing front to back
trunk covered in dynamat
headunit kenwood ddx7015
ma audio line driver/ EQ
ma audio RCAs
just added ohio generator 200 amp alternator
245x35x20
provided you have the correct offset rims theres no modifications needed to make them fit
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
so what size rim should i need exactly like what offset because a friend of mine has some 20 x 8.5 will those be ok
2 massive DMX 12s
2 massive 1500.1
big 3
ma audio RCAs
if your not sure about the offset of his rims, just try them on your car, then you will know for sure.
The tire size listed should be a good size and should keep you close to the stock rim/tire size and keep your speedo right on or close to it.
I have 20x9s on my caddy with 255/35/20s. They are a bit wide but no rubbing.
we cant try the rims on because they have no tires on them and i say why buy the tires if they dont fit
2 massive DMX 12s
2 massive 1500.1
big 3
ma audio RCAs
what kind of car did the rims come off of?
2 massive DMX 12s
2 massive 1500.1
big 3
ma audio RCAs
they came off a 2000 chevy malibu
2 massive DMX 12s
2 massive 1500.1
big 3
ma audio RCAs
  • Who's Online   1 Member, 0 Anonymous, 1224 Guests (See full list)
