Well, I had a little rust spot on the roof of the Suburban, until it snowed... Now it's about 1 sq. foot. I need to get it fixed to make it through the winter (the hood also). I't going to get painted next summer. I know I have to get it down to bare metal, then I have a couple questions on what products to use:
1. Should I hit it with a rust converter to make sure the rust dosn't start from underneath the new paint?
2. High build primer?
3 What kind of rattlecan should I use to keep the weather out? - even a weatherproof primer would be good.
Thanks, Later
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
feather the edge of the paint to keep it from getting bigger than hit it with some primer sealer from duplicolor untill you can get it fixed right
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Will that hold up against the snow and rain?? - I figured I'd just go to bare metal, then out around the spot about an inch or 2..
yes ait will work for the season as long as you do it right as you said. if your going to bare metal get some etching primer on there first to seal the metal then hit it with some sealer.
Scientia est Vox
