have the box firing toward the rear and leave the seat down.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
^what he said
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
With my car I prefer to have the backseat down it sounds louder to me and because of where my amp was mounted (on the back seat) it allowed cold air to get to it so it helped with cooling to have the seats down. But I'm new to car audio so my input may not be the best here.
try it both ways and witch way you like it better. if you fire forward seal it off from the trunk
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Really curious on box specs as I don't see 2 of those fitting in a trunk in the proper size enclosure.
Especially tuned to 27Hz as that's a long ass port if you did 16^2 port area per cube.
As for trunk set ups my experience has been rear facing hits lower, forward firing peaks a little higher and is louder. Also sounds a little better on real music. Of course every car is different...
the specs are 38"Wx17"Hx29"D and by my measurements and using a online calculator it shows that my slot port is at 27hz. :pardon:
I get 9^3 gross, so you're probably way on the small side with port/subs subtracted.
What are specs for the port opening? I see 15.5 high, but how wide is it?
How does it sound so far as this box "seems" to be way out of whack for those subs...
