DC Sound Lab
Box fo two XL 15's
6 cu is fine, just make sure you have the proper port area 13-15 sq in per foot
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
you might want to double check with some of the more experienced guys such as ram_designs or 412 CVX..
but i really think you should be fine with like 6 cu ft
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
3ft3 net per sub will be fine if you have a legit 3000w of clamped power. If you are running a random 3k amP per sub at 1 ohm then you will not get 3k per sub.
If you are planning on 1500w per sub then something along the lines of 3.75-4ft3 net per sub would be preferable.
If you look at the specs for an xl and if you run around 13" of port you will probably get port noise. DC's like big ports from what I have seen over the years.
DC's and small ports is like having a Mustang with a 4cyl........
Edited by Traks
2011 Meca World Champ S3
Team Truth Hertz
Team DC
  • Who's Online   0 Members, 0 Anonymous, 799 Guests (See full list)
