If everything was working correctly before the battery change then its defiantly the battery. Double check the connections and make sure Its fully charged.
had a friend swap his battery and it did the same thing, the connections looked good and his battery was at 12.6, but wouldn't start the car. Turned out the connection at the terminal wasn't tight enough. Took it off and reinstalled the wires and it started right up.
2001 Blazer ~ (2) 10" DC lvl 4's, Orion 2500d 148.9db
2005 Astro ~ (2) 18" DC XL's, Atomic 5000.1 153.9 db
New England SPL
NESPL - YouTube
happend to me i put wrong terminals on but everything worked. car didnt start.
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
clean both terminals also with a terminal brush. sounds like a bad connection if your sittin @ 12.5v ...... my car starts sittin @ 11.2v peepwall.gif
and i would take a look at where the wire connects to the terminals too..... corrosion would do it. just had a car come in at work (88 mercury marquis) was sold to us CHEAP "not running" i messed with it and found out the wire from the pos. terminal to the starter solenoid was shot ( 1 ft wire) so i jumped it from the solenoid and it started right up. work FTW.
not trying to thread jack lol just showing how something so stupid can cause this.
good luck :)
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
  • Who's Online   0 Members, 0 Anonymous, 2387 Guests (See full list)
