Cadence amp information
soundcheck11
Best input you are gonna get should be from me i´m guessing lol, i´ve seen many people using the C5 but almost no one with the C7, i used a C6 for almost a full year, and i´ve tested the C7 a couple of times on a friend´s car, the specs are on 18v iirc , i clamped 2800 watts @ 3.8 ohms dropping to 12.5v on my old C6 , it´s a beast amp for sure that can take TONSSSS of fucking abuse, mine took lots of vibrations for more than a year until it died, but that´s was the reason and nothing else.
The C7 CAN TAKE 0.5 ohms daily if you have the electrical to back it up, 0.75 ohms should be safe if you have a nice batts and alt, that amplifier sounds awesome on music and can take tons of abuse, just know this, you ain´t getting 7K from that amplifier wired at 0.75 ohms with a voltage around 13v , 5K is the most you are gonna get from it if you are lucky...
Thank You for your input! Think i will go for a couple different amps as i dont neccessarily want to go out and spend another few $$$g just for 6volt batteries and regulators and stuff. Thank You Sir!
My pleasure man, if i were you, i would get an AQ3500.1 , that thing can give you around 4500 watts @ 1 ohm around 13v , go to their web page and check it out, best bang for the buck out there IMO...
