Looking for someone that knows and has used Cadence amplifiers before. Looking at the Cadence ZRS C7 7000d amp. Would like to know if it would be stable enough at .75ohm.
Thank you for your help
Jordan
What is it rated at?
you might be able to call cadence and get this info
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
are you sure its rated at that much at 14 volts or 18....
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
doesnt say it has to be powered by 18v just says it can handle up to 18 volts. but like most have said i realizse the power will be greater at an 18v input. I did read somewhere on the cadence website that there testing was done at a 14.4v. but i do appreciate the help guys. still looking into amps to get for my set up. even with a this amp it would still put out what id need to 4 w7's at a lower voltage than 18v
