Ok, so I just bought a new kenwood headunit it came with the wiring harness and i matched up the colors to the wires in my 1984 toyota pickup based on the wiring diagram here: http://www.modifiedlife.com/1984-toyota-pickup-car-radio-wire-color-codes/ and the wiring diagram that came with the head unit. but it powers on (i can hear it and i can put a disc in and eject it.) but it wont light up buttons or display anything! please help! not sure what other info to post but yeah :(
do not post your topic in multiple sections trying to generate traffic.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
H/U could be effed up make sure your illumination wire is correctly spliced.
i would say check connnections and use common sense. not all instructions are applied to every vechicle. you may have a unique case. or ffaulty H/U
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
u had like 15 legit answers on ur other post y post again in a different section? did u even try what we told u?
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
:ohsnap::lazy: :lazy: :lazy: :lazy: :lazy: :lazy: :lazy: :lazy: :lazy::No:
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
If it's a removable faceplate, the faceplate could not be seated correctly or not all the way seated. If that's not it, then it's probably a defective deck.
just because you hear it power on doesnt mean its hooked up correctly. have you tried the easy way and running it write to a battery. black to ground yellow and red to positive and see if it turns on. my guess is no.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
