Was looking into buying one of these off of someone for $200 locally but now that im reading about it, it says that 0 gauge is recommended, problem is I only have 4 gauge and dont plan on having this car forever so I really dont wanna do 0 gauge if I dont have to.
Can you still run this amp on 4 gauge? I'm getting like 12.5 volts with a Kinetik HC1200 hooked up in the back too.
one of the best way to kill a amp is to use to small of wire ...the hifonics amps require alot of current to run if u use a stock charging system and 4 gauge on that amp u may as well throw it in a fire and save killing your car.... :nea: get a smaller amp or upgrade ur wire and get some batts
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
pulling 240 amps through wire that can handle only 150 amps. yeah that will work out just great.
Thats why I ask... To get help
you dont even have to ask. you always use the biggest wire that can fit in an amp. always. theres a reason why amps have specific gauge inputs.
Edited by Kranny
