hey there guys I have a trunk car system and i have put sound deadener on my trunk lid, on my license plate and i have also put expansion foam inside the trunk lid, but yet i still rattle like a mother and it is coming from he trunk. Any ideas on what to do to remove or dampen the rattle? thanks in advance for the help.
put foam inside the weather seal area. thats whats rattling most likely
as well as the area where the latch is.
some cars are able to have the ring that the latch attaches too move down for a tighter fit.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
id be verrry careful if you put spray foam where the weather seal is if you put too much it could warp it then it will be raining in your trunk.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
ive known people to actually spray it into the weather seal. since its a hollow seal
Could I use dynamat on the trunk lid where the weather seal sits?
it wont help much.
Have you adjusted you latch down(if possible) so it holds the trunk tighter?
use some duck tape on the latch hook of the trunk also on some cars there are shields under or near the bottom of the trunk make sure there not touching or not to close to anything...bets thing to do is turn it up and find each rattle and try to kill it with what ever you can if it bothers you
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
