armykyle1 Posted January 30, 2012 Report Posted January 30, 2012 sexy sexy! TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
OrangeJuiced Posted January 30, 2012 Author Report Posted January 30, 2012 Try moving the sub baffles back to give the subs about 1.25 sealed instead of 1.7, you can always add poly-fill later to gives the subs the illusion of a larger enclosure. Then take out the center divider. Doing this should give you a 2.3 common ported chamber area. I dont know measurements for port as I dont have a computer. But after sub displacement in sealed chambers you should be close to the 2:1 port to sealed ratio. You can still use your box you have now, just tweek the baffles and make a new port for tuning. Good luck, the truck looks amazing! The sealed portion is 1.3 already. If it were larger i'd totally attempt that. With the new box it is going to be 1.4 per chamber, not following the 2:1 ratio. The new box is a box my dad has used for years. Thanks for the suggestion though, I take any advice you guys give into consideration. Thank you 2001 GMC Sierra Build. Body dropped and Juiced
KHRISS Posted January 30, 2012 Report Posted January 30, 2012 thats one bad ass truck nice build CURRENT SYSTEM (VEHICLE) 2005 JEEP GRAND CHEROKEE (HEAD UNIT) KENWOOD KDC BT848U (DASHBOARD) INFINITY KAPPA 32.9CF (FRONT DOOR) JBL P693 (REAR DOOR) KENWOOD EXCELON KFC-X1730 (TWEETER) KICKER KS25 X 2 (SUB WOOFER) COMING SOON (4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP (1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2 (PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC (BATTERY) 1 OPTIMA YELLOW TOP (SIGNAL WIRES) KICKER XI (POWER CABLES) KICKER PKD1 (SPEAKER WIRE) KICKER 12 GAUGE (INTERIOR) DYNAMAT COMING SOON 2 FI SP4 18 COMING SOON 2 XS POWER XP3000 COMING SOON DC POWER 270XP ALT COMING SOON
OrangeJuiced Posted February 16, 2012 Author Report Posted February 16, 2012 Ok guys, been doing some testing with the box and speakers. Tore it apart and tested a 1:1 ratio with the same box. It did sound better. Same day, I took it apart and did a 2:1 ratio, but I only hooked up one sub! So at the moment that's all I have. Its hard to tear this thing apart being a daily driver. So here are the pics of the redo. Tight Fit! 1:1 Been pulling this box in and out so much I figured it would be easier with plugs Also did some wire moving and fixing the interior for the blow through. Once I get this box figured out, I will start the center console and front stage. Moved the stock wiring up and mounted it there Then put the carpet up and added these factory push pins at each edge of the hole Then tucked the carpet over the boot, thought it looked clean. Havent started on the plastic piece yet, but plan on something similar to the carpet so it looks clean. I would like to build a frame around the hole and wrap the frame with speaker grill material, then glass the frame into a center console so all you see is the speaker grill cloth. Still having problems with the box and speakers at the moment. Being body dropped and having the hydros back there makes it hard for a box design. 2001 GMC Sierra Build. Body dropped and Juiced
meade916 Posted February 16, 2012 Report Posted February 16, 2012 one of the tightest rides on the site just got tighter.....keep the pics coming! Love the bandpass cut-through bro. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
BEEMDUB Posted February 16, 2012 Report Posted February 16, 2012 I normally aren't that big of fan of slammed trucks but you have nearly changed my mind your truck is sick man! Love that you did everything yourself great job! Deff will be keepin up with this build
ctdv55 Posted February 16, 2012 Report Posted February 16, 2012 Amazing job on the truck. I've got a bed cover waiting for my 92 C1500, just can't bring myself to do a blowthrough in it yet though. 2010 Honda Accord EX-L 3.5 Sedan Mechman 320 Amp Alternator XS Power D2400 Alpine CDE-HD149BT Stinger RCA's Ampere Audio 150.4 4 Rockford Fosgate Punch Pro 6.5"s and 2 Super Tweeters Per Door (For now) Few goodies coming soon for the trunk.
OrangeJuiced Posted February 16, 2012 Author Report Posted February 16, 2012 one of the tightest rides on the site just got tighter.....keep the pics coming! Love the bandpass cut-through bro. Thanks Steve. Still adding to it I plan on driving it down to Arizona over summer. Maybe stop by your shop? I normally aren't that big of fan of slammed trucks but you have nearly changed my mind your truck is sick man! Love that you did everything yourself great job! Deff will be keepin up with this build Thanks man. Glad you like it. Amazing job on the truck. I've got a bed cover waiting for my 92 C1500, just can't bring myself to do a blowthrough in it yet though. Eventually you will man, you can only fit so much in the cab haha. i want your paint!!!!!!!! Haha thanks. You guys are keeping this build going. I'm working on the box when I get home from school. I have also started a led lighting system for the truck. I'll upload the pictures when I get home. 2001 GMC Sierra Build. Body dropped and Juiced
Jaloosk Posted February 16, 2012 Report Posted February 16, 2012 Your truck looks great; good luck with the new box build. "Cheap, good or fast. You can only pick two out of three." "Have money? Love story! No money? I'm sorry."
