if there is no oild ur may have killed the car....i didnt see u couldnt get it started earlier ...enegine may be locked check under the car and see if its soaked in oil or if there are any holes in the engine block or oil pan...if so its time to find a new car.....srry man i know this sucks :peepwall:
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
I was thinking the same thing. When I put the car on the tow dolly I checked to see if there was any sign of damage. But with some much crap under there its was kinda hard to tell. Guess I'm gonna start lookin for a new car. Hmmmm what to get.
Its pretty much confirmed, my engine is gone. My grandpa suggested putting oil in the engine and seeing if it would run. Well I put in almost 4 quarts, not enough to fill it full. But surely enough to show up on the dip stick. I waited a few minutes and checked the dip stick, it had nothing on it. Even after adding nearly 4 quarts of oil. The oil pan looked fine when I put the car on the tow dolly. So maybe hole in the block?
Posted (edited)
Ether way it is done if you put 4 quarts of oil in and it did not show it has to go somewhere. So if it is not leaking and would be able to tell if there was 4 quarts of oil under the car. Then it could be going in to the cooling system see if it has oil in it. But It sounds like the engine is ceased.
Edited by 14dbass
Suburban Build Log
"So much money and time spent making copper winding move up and down a magnetic pole"
DC Audio Eclipse
if its dry you seized her up. byby baby.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
chack under your radiator cap. foamy?oily?, oil cap?nada?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
  • Who's Online   1 Member, 0 Anonymous, 529 Guests (See full list)
