Posted (edited)
I need to make a new box for my truck and want to try a 4th order. Right now my sub is in a 3cu.ft. box and every time someone opens the door it gets louder.
The sub is a Rockford Fosgat P212S4. 12" single 4 ohm voice coil rated for 300rms.
I would like to start building it this weekend.
Edited by C.Sanchez.A
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
Those external?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
are you rebuilding because it gets louder when you open the door or just to try a 4th order out? what vehicle?
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
For a single 12, i would do a higher tuning, such as 48hz or so, because of the big box it will already want to peak low, because the 4 cubes is on the big side.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
The vehicle is a 1994 Mazda B3000 (Ford Ranger). I'm rebuilding because the box I have was not built for this vehicle and I think this sub would do good in a 4th order. Plus I want to experiment and learn.
Youtube Channel
alright i was just wondering..and if you were to stick with those dimensions i would go with wat socky said and tuned in the higher 40's...and i would have it loading off of the passenger side wall as that is where those trucks seems to get loudest
power: dd m4
