DC Audio Trunk Build 50.8db
Burp it with both amps then put all subs on 1 amp and test
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
im just happy it was not a blown sub and i dunno how many times i told mario SOMETHINGS wrong been there many times and you would not lose 3 dbs by changing a port by a half an inch
i thought it was driver side that was not working but mario said the rca was for the pass side hard to tell when the comperrsion of one sub moves the other
I hear that. I'm wondering how it did it, with twice the usable airspace and the possibility of a little bit of cancellation from that other sub doing exactly the opposite of the sub that was working. Really interesting. Edit: Half the Power Half The cone Area Box is twice as big Maybe a little cancellation Say Half the output.... Ehh... I'm thinkin outloud. Shits crazy.
nothing is wrong with sub/subs they are perfectly fine. just one of the RCA wires was not in all the way causing sub not to work. how it had happen not to sure maybe when I was trying to clamp the amps i could have knocked it loose. Its tight back there.
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
there D1.4 so the ohm loads would not be the same with 1 amp and 2 amps
I understand it was just an RCA. I don't understand the output.... Twice the cone area and (Theoretically) twice the power yeilded 3DB. But the airspace of the box was doubled and cancellation might have been a factor when the RCA was unplugged. Hard to catch where I'm going with this, because I don't know where I'm going with it. It's just weird that it happened to put out such a high score when it was in a box that was (possibly) too big.
i see where your going blacked out its strange how it works
same thing happend to me but the subs were in separte boxes did a 152.1 iirc an rca pulled out and still did a 149.x adding the second sub only added less than 3 dbs
you would think 2 subs doing a 149.x each would have more output than an add 2 dbs
Now I see what your talking about.
hmmmmm......
148.5X2=297db
hmmmmm......
148.5X2=297db
Lol... The Theory is that double the power adds 3db. Which is cool. You had half the power, you lost 3 db.
But that doesn't take into account that you doubled the airspace, and 113 sq inches of your baffle acted like a passive radiator with a magnet.
hmmmmm......
148.5X2=297db
Barely louder than Meade (from a video)
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
  • Who's Online   0 Members, 0 Anonymous, 6935 Guests (See full list)
